randyray41
- May 31, 2011
- 123
Had my boat in shop 3 times in last month. 70 hp Evinrude model # 70873C. My issue is it will idle, but it has no pulling power. It won't get over 2k rpm while in gear but in neutral it will rev up fine.
So far, my boat mechanic has replaced all fuel lines,as well as bulb, and I put in a new 9 gallon fuel tank. Fuel pump rebuilt as well as cleaned all 3 carbs. Spark check is fine. yet same thing happens over and over. Boat has 125, 124, 125 compression. The first time it was a piece of trash in bottom jet, after it was cleaned boat run great for two days then same issue, back to shop it went. thats when he cleaned the other 2 carbs. Picked boat up and last Sunday back to water. It ran for about 300 yards, I idled down to go back to dock and same crap again, would not go. Will run about 2k rpm. Loaded it up and back to shop it went.
It will crank right up, but it will not go. Now he is saying it may be stator? Something about low speed and high speed part of stator since i'm not a mechanic, I don't know.
Anyone have any thoughts on what may be the issue?
