I've been working on getting a 6 hp johnson resurrected and I think i have an issue with the high speed circuit or fuel pump. I can spray fuel in the carb throat and it will fire, if I close the choke and pull several times it will run briefly then die with gas visible in the carb throat but won't stay running. Is there a method to test the fuel pump to rule out that as a problem or do i need to somehow clean out the high speed jet. How does one do that in that it is pre-set high speed jet? Any help would be greatly appreciated. Thing seems to want to run and it is so close it is starting to drive me nuts. Thanks.
