I understand how it works, the charge of air being pulled in as exhaust comes out, wanting the exhaust to start exiting first etc. It just doesn't look right to have designed a port that is 1/3 blocked by the piston even when it's fully at it's most open position. I've worked on a lot of 2 stroke engines and usually if they put a port there and it has a certain size opening, then it's intended to be used, otherwise they might as well have made the port only 2/3 the height and have the same flow through it and a stronger cylinder wall with more metal. I know the piston is stepped up differently to control the timing and flow of the air charge. Since I have the engine mostly torn down I figured now's the time to change out the pistons (IF they're the wrong ones), but if they're supposed to be designed like that then I'll leave em alone.
