Pull cord won't pull
Status
Not open for further replies.
FishMagnet
This is my first boat, and my first outboard motor so please bear with me. :)<br /><br />I finally got around to attempt starting the motor. The electronic ignition was not functioning, but I expected that. I tried to turn it over manual with the pull cord but cannot get the cord out more than 2 inches. The engine is in neutral. <br /><br />ANY help getting me started in the right direction would be appreciated. Just dumb it down for me. lol<br /><br />Thank,<br /><br />Matt <br /><br />Oh yeah, its a 1960 (RD-22) Johnson Super Sea-Horse 40.
Paul Moir
Re: Pull cord won't pull
Welcome to Iboats!<br />Try to turn the flywheel (large toothed wheel under the pull-start) by hand. If it turns fine, then the problem is with the pull start. Is there's still a linkage running up on the right side of place on the pull start where the rope comes out? That's a lockout designed to keep you from pull-starting the engine if the throttle is set too high. It shouldn't be 'activatable' if you're in neutral, but who knows?<br /><br />PS - I noticed you called the electric starter an 'electronic ignition'. There's something you may need to know that is very helpful: the 12v starting/charging system has absolutely nothing to do with the ignition system (sparks) on your outboard. Other than the kill switch, it is self-contained and totally independant of the boat's other electric systems.
FishMagnet
After my frustration subsided I went out for another round with the beast. :) I managed to manually move the flywheel, which allowed the cord to work. I pulled the cord...nothing, though the flywheel did turn. I decided to try the key once more, and voila the starter worked and turned the flywheel. No spark though...<br /><br />Matt
itstippy
When you say "no spark" do you mean:<br />1) The motor doesn't "cough" like it's trying to start.<br />or<br />2) You've pulled the spark plug wires and tested them against the engine block while turning the motor to see if there is any spark. You have no spark at either wire.<br /><br />There is a big difference.
Paul Moir
Do you happen to have a compression tester? If not, borrow or obtain one. This will let us know if the engine has anything seriously wrong with it, since you'll soon be deciding whether to fix it or give up on it. If the compression is good, and the lower unit seems fine (check the oil for water/metal chunks), repairs can be made fairly inexpensively.<br /><br />Don't sweat the lack of spark. Parts for it are cheap and available. How often do you hear those words when it comes to outboards? :) For now, just make sure that the two small black wires that come out of the engine are not connected to anything, especially each other. You can go a step further and disconnect/isolate the two small black wires that come down from the armature plate up underneath the flywheel. Don't start the engine up like this though.<br />The ignition system is completely independant and both cylinders are independant from each other. So it's entirely possible to have spark on one but not the other. When working properly, you will be able to draw a spark 3/8" long from each lead.<br /><br />Any history on this engine? Was it just stuck a bit? If so, when turning the engine with the spark plugs out now is there any binding?<br /><br />One other thing: wrenching an outboard is an exercise in paitence. If it's getting the better of you, take a break and relax. ;)
FishMagnet
Bear with me, I am a beginner here. :)<br /><br />I'm sorry for the confusion, when I said no spark I did indeed mean it didn't "cough" like it was trying to start. How do I test the spark plugs wires against the block?<br /><br />I don't have a compression tester, I'll see if anyone I know has one I can borrow. <br /><br />The engine has run well for a long time, up until probably 5 years ago when my wifes Grandpa could no longer use the boat. It has been sitting in a barn basically untouched except for when my wifes Uncle would come out and make sure it hadn't "locked up".<br /><br />Matt
Mark42
Make sure you have the motor in a trash can full of water or the muffs connected to a garden hose. Running without water will ruin the water pump in as little as 20 seconds. Not sure what a '60 Super Seahorse cooling system is like, but I am sure it will over heat without water.
Paul Moir
Ah, it looks like I was getting a bit ahead of where we're at then. Mark42 is absolutely correct - you do not want to start this engine unless it's in a bucket of water filled up to the seam between the lower unit and the mid-section. That is the bolted joint that is 3 or 4" above the horizantal plate above the propeller. Forget about muffs - the type that fit your engine are very hard to find.<br />Don't worry too much about impeller damage now; you'll have to replace it anyway. It's best to replace them every season or two, notwithstanding use since they go bad just sitting around. Yours is definitely too old.<br /><br />There's many ways to test spark. There's little adjustable testers you can get from auto tool stores for a couple dollars which work very well. But you can construct one out of a couple nails banged into a peice of wood. The idea is to make an air gap around 1/4" wide and connect one end to the spark plug wire connector and the other needs to be electrically connected to the metal of the engine (just about anywhere, really, so long as it's part of the 'block' or directly joined to it. I habitually use one of the electric starter-bracket studs). Crank the engine fast (with the plugs out) and you should see it nice big sparks across the air gap.<br /><br />A compression tester from a discount tool place will run less than $20, or a lot of retail auto supply stores have tool lending programmes if you don't know anyone who has one. They're pretty easy to use - you just screw it into one of the spark plug holes, crank the engine for 4 or 5 complete revolutions, and note the reading on the guage.
FishMagnet
Thanks for the input. I could always take the motor in to a local shop, but I really want to learn how this thing works so I can take care of it myself. <br /><br />Matt
Paul Moir
Once you confirm the engine is up to snuff, we'll point you towards a few good service manuals. In the mean time, you can often borrow them from your local library - it's worth checking out.
FishMagnet
I am proud to say after some hard work the motor is now running. Now I didn't say it was running smooth, but it will stay running. <br /><br />I let it warm up for awhile and water is coming out of the discharge, more of a spray rather than a stream. Is the spray normal or might this indicate a pump going out?<br /><br />Also it creates a LOT of smoke. It is an older motor and I do have to add a lot of oil in with the gas so I assume this is some of it. Should I let it run for awhile and see if it settles down? I'm a little afraid. :)<br /><br />Thanks,<br /><br />Matt
Solittle
Matt - Were it mine I would follow Paul's suggestion and do the compression check before you run it again. (A motor will run with bad or little compression.) You don't want to chance the old impeller in the water pump breaking up and pieces getting stuck in a water passage somewhere. If the compression is OK (post results here) you can proceed to change the water pump and other "stuff" to get it back in service. At that point you also should think about getting the OMC shop manual.
Paul Moir
Good news! Ditto SoLittle's comments.<br />You're going to want to service the water pump and tune up the carb, adjust the spark advance syncronization, check the thermostat, decarb the engine and tune up the ignition after you run that compression check. Factory manuals are best:<br />TheOutboardWizard<br />Mastertech<br />Marine Engine<br />Ken Cook <br />They're more expensive then the Seloc one, but they're well worth the extra $10. Sometimes they turn up on ebay used for a fraction of the price, but I don't see any right now.<br /><br />The smoke may be left over oil and such in the engine. It may also indicate you're running too rich. You should see a healthy amount of water come out the hole in the back of the midsection once the engine warms up a bit, and the thermostat opens.
FishMagnet
Thanks for all the quick replies. It'll be a couple days before I can get back to the motor, but I wrote down a list of things I need to do. <br /><br />Thanks again,<br /><br />Matt
Status
