pmoxsib16
- May 31, 2016
- 15
I have recently installed a 93 ocean pro 150 on my make center console...when I turn the key on I get a quick beep from the alarm...is there a way to test the sensors to make sure they set the alarm off...for example grounding or powering the coolant sensors to make sure they turn the horn on or the same with the oil system...i want to make sure the alarm will work when it needs to
