Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
2000 Johnson 90 hp water pump change
  • 2000 Johnson 90 hp water pump change
    I need to change the water pump on my 2000 Johnson 90 hp outboard. Are there any tips or tricks I need to know before I can drop the lower unit? Any tricks to putting it back together?
    Re: 2000 Johnson 90 hp water pump change
    Click on the red "search" above and do a search on pump replacement. I'm sure you will find more than enough info. Make sure you have a manual and do the whole pump kit, not just the impeller.Good luckDave
    I get by with a little help from my friends
