Can'tFishEnough
- Apr 19, 2011
- 86
Hi, I have a new to me '79 Evinrude 55hp that has the tell tale indicator outlet on the lower left (port) side of the engine block. I'm working on figure out what all gauges I need to get for it other than a better tach than my knock off tinytach and started looking at temp gauges. Then I started coming across post and comments online about people moving the water outlet to a higher location on some late 70s early 80s models because of overheating and blowing the head gasket. I guess there were some service bulletins about it.
One thing I saw -and maybe it's just for a temporary work around (I think it was on iboats, but can't remember) was that if the hose is routed from that low location over the top of the block before going back down out of the engine cover that it wasn't necessary to drill and tap a new location.
Ideas? thoughts? Thanks.
