Fowl_obsession
- Jul 5, 2015
- 29
WHAT I HAVE: 1977 70hp 3cyl johnson and parts motor that the old owner said had bad compression.
MY PROBLEM: I got the motor running about two weeks ago, everything was going smooth. Last week i went to warm it up before i checked compression. It bogged down and acted like it was flooded so i took the plugs out and cranked it. Lots of water sprayed out. I took off the lower unit and the head. When in the lower unit, i found a small washer just sitting there on top of my water pump housing like it had been just floating around.when i took the head off, the gasket looked fine, my bottom cylinder had been beaten to heck. A bunch of noches in it (could have been the washer?) My pistons have "0.03" engraved on them.
What are my options?
