Hello everyone. Just ran into this today. Put a good running 1982 Evinrude 25 on a pontoon barge I use for moving things back and forth between an island and shored. Started right up runs good. Took for a test run and everything worked great. Docked it for about an hour. Started up in one crank. Motored out about 100 yards and it started bogging down and losing power. Limped back to the dock. Runs perfect at idle. I can rev it all the way up , out of gear. Nothing in the prop. Plenty of new fuel. New oil in the lower unit before I put it on the boat. Checked compression when I pulled it out of the garage before I put it on. Nothing seems to be obstructing the carb. Any Ideas?? The confusing part is that it was running perfect , then just changed, like something is restricting. The gas flow, but it runs fine out of gear. Doesn't change if I add choke.
