The motor ran great last year until the lower unit hit something under water and I lost the prop, prop shaft, and the seals. I rebuilt the lower unit and tested the motor. It wouldn't hardly run at all so I checked both carburetors and the needles were bad so I rebuilt the carburetors. Next I cleaned the fuel pump. The motor still ran pretty bad so I checked forums for some information and found that the carbs have fixed needles, in order to adjust it the timing needs to be adjusted I tried adjusting the timing while the engine was in gear in the water but haven't gotten anywhere. When the motor is in gear even idling i have to continuously bump the choke button to keep it running. To get the motor running as high as I can get it while in gear I have to bump the choke button as fast as possible while taking the throttle up and down until the boat gains speed. Before the problems I could get the boat up to 24 MPH, now it will get to 12 MPH.
Both cylinders are firing and both carburetors are working but I can't find any information online to fix the problem.
Any information would be greatly appreciated. I will post images of the motor and timing linkage/carburetors soon.
