pmoxsib16
- May 31, 2016
- 15
So I'll keep this short and sweet...like the title says I have an 87 evinrude 175...started running bad yesterday...pulled the plugs this morning and found water on them...pulled the port side cylinder head and found a Crack in the top cylinder sleeve and the walls of the block that the sleeve is pressed in to is split...should I invest in a remanned powerhead because otherwise it ran great...or try to repower with an updated motor...boat is a mako 20ft center console...just looking for opinions...maybe a point in the right direction.
