Kevinhand26@
- Jun 18, 2016
- 8
Motor will not crank unless gas is shot through the 2 clear hoses to the carb. Its my understanding that pressing the key in before and while cranking it was supposed to let the gas through those two hoses. If I manually turn the red knob it let's the gas through then I turn it right back it starts fine. I am thinking about replacing the primer but I don't understand what is supposed to trigger the primer to work when I press in the key (which I originally thought was a choke) I see no wire going to the primer am I missing something. Any help is greatly appreciated
