airbus320
- Oct 14, 2015
- 20
1977 Johnson 70Hp 70EL77S
I've done some pretty extensive searching online and on this site without any conclusive results.
I am moving the batteries on my boat to the bow for weight and balance. I have a dual battery setup with a [FONT=Arial, sans-serif]Attwood 4-Way Battery Selector [/FONT]Switch.
This is a fiberglass boat. The round trip length is approximately 30 ft. from where the old battery location was, the ends of the cables coming from the engine are located in the stern. There is approximately 4-5 feet (8-10 round trip) of cable from where the batteries used to be in the stern. Those cables go through a harness and directly into the engine.
I have looked at many different charts and guides to help me determine wire gauge, but have come up with mixed results.
Thanks for your help!
Joe
- What would the recommended wire gauge be for this run?
- Can I splice the new wire to the existing cables that go to the engine or is it recommended to replace the entire run from the battery, through the harness to the respective cable connections in the motor? (that will add another ten feet R/T to the run approx).
- What is the recommended circuit protection for the battery to engine run? I have a maxi fuse holder Blue Sea Systems MAXI Fuse Block - 30 - 80A that I planned to install at the battery end of the run, for exclusive protection of the battery to engine circuit.
Joe
