Reqarding your post #18, removing the seals - I just did this this past weekend during my LU resealing project (1985 25hp Johnson, also pulled bearing carrier with a harmonic balancer puller, but I had the threaded holes to work with). They do make a bearing puller tool, but if you take a sturdy flathead screwdriver and carefully and slowly work the blade around the inner part of the seals, they should come out. Careful not to damage the housing/casting.
