I am attempting to rebuild the lower unit on my Johnson 40hp motor. I have removed the prop and the bushings that rest against the bearing assembly. I also removed the 3 bolts inside bearing assembly. Now I am attempting to remove said bearing assembly. I watched a video and it mentioned using the two bolt holes and use a puller to remove. This was on a 115 Johnson. The 40hp does not have bolt holes to screw into. Is there a method for removing this assembly? I attempted to rig the puller using threaded rod but don't have anything to screw it into.
