My motor will only run for a minute or less wot before it bogs down and won't maintain high RPM. It'll try to get back to normal only to bog down after a second so you've got a second of acceleration followed by the motor losing power. Pumping the primer seems to help, so I cleaned the carb, made sure the jets were clear, and rebuilt the fuel pump with new gaskets and diaphragms. That didn't work. I'll be buying a new primer bulb after work today in hopes that'll help. Any suggestions?
