Cherokee-Runabout
- May 30, 2012
- 90
Please help if you can! Any ideas or suggestions are greatly appreciated! I've been having a little trouble shifting into my forward gear (reverse seems to be working just fine) when I shift from neutral to forward at the gear box there is an excessive amount of grinding. I've had to back it off or else engage the lever all the way forward before the gear would grab. I had a similar problem with another l/u that I had. Is this a problem with the length of the linkage? I'm not very well versed in the art of outboard repair so any help would be great! Thanks for reading.
