I'm thinking of replacing the fuel pump with a regular one instead of the VRO which is capped off and not being used anyway. Would anyone know what pump part number I should get? Also having a hard time finding parts for this particular model engine J50TLEOD. Need the carburetor cover gasket ( old one is ripped ) and the gasket that goes on the front of carburetors between the cover and the carbs. It's also in bad shape and could be causing excessive air to enter carbs.
