pmoxsib16
- May 31, 2016
- 15
Hello my name is Paul I am having a problem with my 1987 evinrude 175 outboard. The throttle lever attached to the side of the motor does not seem to be returning all the way and it is causing a high idle...close to 1500 rpm. I can push back on it with my hand butterflies on the carbs close all the way and the idle drops back down closer to 1000 rpm...I'm not sure what is causing this...all the throttle return springs are there on the carbs rhemselves...does anyone know if there is another spring that is supposed to return the lever to its home position after moving the throttle back to neutral?
