scout-j-m
- Jul 31, 2009
- 636
The driveshaft on my 1982 9.9 hp Evinrude is sized in the crankshaft splines. I was able to remove the LU by pulling the driveshaft out of it and through the water pump housing. I have it upside down right now soaking with PB Blaster which is all I had on hand. What would the best penetrating oil be for this situation? And any tips for pulling it after it has soaked? I tried after a few days of the PB Blaster to use a pair of small vice grips, tapping on them with a hammer but it didn't budge.
For what it's worth, I'm converting from long shaft to short, so a damaged driveshaft wouldn't be that big of a deal to me. So if all else fails and there is a good method of removal where it may be damaged beyond repair I am open to it.
