Mike-Boston
- May 29, 2016
- 9
Points are set correct, they open and close properly.
Both coils have same ohm reading.
I unpluged main harness - this is a mag set-up and should run alone.
I have checked all wiring connections.
Last year it ran fine.
Help.
PS at one point I had plug fire on bottom plug, so I switched coil and condencer to the one that had NO fire, and the bottom still had fire.
And now I have NO fire at all.
Help
Mike
Help.
Help
Mike
