1984 Johnson 70 hp outboard.
After an overnight fishing trip, I was pulling up to the boat ramp in forward at idle speed. Shifted to neutral, than reverse. Gave a quick shot of gas to stop the boat, and the boat lunged forward grounding itself on the ramp.
I pulled the motor cover off and checked the linkage. The shift lever is moving back and front as it should, but the prop is stuck only turning forward.
