JrMechanic070
- Jan 28, 2015
- 12
Hey guys, I have a evinrude 40hp outboard that I'm trying to get running. I took it out monday and it ran perfect at all speeds. Then I took it out on tuesday and it started having problems. It runs great at idle, and great at full throttle, but it doesn't want to run at mid range..!? If you jump it up from idle to full throttle it runs great, and if you bring it down from full to idle it will work. But if you accelerate slowly it starts to sputter and shake and die around mid throttle. The same thing if you bring it down from full it mid throttle. It just wont run right at mid range. I cleaned out both the carbs. Completely disassembled them, sprayed them out with carb cleaner, then blew them out with a compressor. I tried adjusting the screws on the top of the carbs with no results. The engine has 140 psi even on both cylinders, and great blue spark on both cylinders. It has brand new fuel lines and bulb from the tank to the motor, and it has new ethanol free gas. I'm really stumped here, and I need to get it running by saturday. Any help at all will be greatly appreciated. Thanks
