Well, you could install the solenoid in the lower pan and install push-button start and kill switches through the pan also, or run the switches up to the boat dashboard. Nothing sacred about the junction box - it just makes things easier with an electric start/electric choke motor with a plug for the electricals. Don't you have the junction box?
Solenoid is part # 378444
Ignition switch kit is 386545
