When I am at low or idle speed there is no water coming thru the hose and engine overheats. At higher speeds, water starts pumping out the hose and also through the rectangular exhaust outlet above the lower unit. I don't remember ever seeing water out of that exhaust port... Is this a pump going bad or possibly another simpler issue? The hose itself is not plugged.
