when on plane and at high rpm the motor will run a few hundred yards then start to bog like its not getting fuel. pump the ball a few times and its fine for another couple hundred yards. has a new ball and new fuel lines, also a new fuel pump, motor ran fine and then started doing this, was wondering if it was the fuel filter maybe or if there is any other things I should check
