my 1987 25hp johnson has a manual primer u pull out to inject fuel into the carb but if i move it she will leak in the case and the c clip will fly off somewhere....
so is there any way i can bypass this primer for the time being?i have another electric choke bowl and i was just gonna swap out the bowls and do away with any primer all together.
there is a nipple coming off the intake right below and to the left of the carb (while looking directly at carb) can i route that small tube to the top of the carb so it just cycles back thru the intake?
