B.autry4711A
- Feb 24, 2005
- 176
Hello again,<br /><br />I have a question. I am going to replace the water pump and after looking at my new Seloc manual took the cover off the motor and see what I need to do to remove the shift linkage. Looks like I will have to remove both carbuetors to get to this. Now since I am removing the carbs I might as well clean them out. Do I need to rebuild them or can I JUST TAKE THEM apart clean them out and replace just the o-rings and gaskets. I don't want to goof them up. I am hoping that all I have to do is remove take them apart and clean them and put them back together. The motor ran good last year, don't want to screw up the orifices, little paranoid about messing with the carbs. I want my boat to run. Also if I do this will I have to adjust or will be alright? Thanks again I have a 1987 Evinrude SPL 88 Horsepower V-4 outboard motor.
