Please help. 1987 evinrude outboard will start every time, run for twenty second then dies. Model number is e40ecud. Boat mechanic cleaned the carbs and replaced spark plugs. After I got it home I started it and it ran for a 20 seconds then died. Figured it was a fuel issue so I've replaced the primer bulb, gas tank fitting, fuel filter and rebuilt the vro fuel pump.(vro is disconnected running 50:1 mix) after all that boat still dies. Sent back to mechanic and he claims that its the fuel pump. Picked boat back up before he did any work to check pump. Disconnected line from pump to carb and pump put out 2 fl oz on twenty seconds before it died. Did the same thing three times with the same result. Boat will die regardless of i pump the primer bulb or not. Is the pump the issue or should I be looking elsewhere?
