chead98
- Sep 11, 2009
- 82
Hi. Just picked up the boat from winter storage and decided to hook up my fully charged batteries and test her out. As soon as I try and trim it down some, the tilt/trim gets stuck. Finally after 10 minutes it lets go and works again. Then I try to start it but the starter spins really fast but won't pop up and engage the fly wheel. Even though I probably didn't need a new starter, I got one anyway and installed it. Nothing has changed, same problems and tilt trim is acting up again. I installed a new relay for good measure, and all battery connections are clean and checked. Just to note, I do have two starting batteries hooked up in parallel. That's because my batteries would keep dying on me for some reason in the past. Could this be the solenoid or water in the cylinder? I don't think it would be battery connections as it seems I have lots of power going to the starter and trim. Unless I have too much because when I turned it over yesterday I heard a spark crack from the batteries. Hope this post is not to confusing o too long.
Thanks in advance, Chris
