Removing the controls would be easy compared to trying to assemble an engine through an intake passage. It is not possible to do it properly, and expect it to run. Right now you are looking at 1 piston, 4 sets of rings, possibly 1 cylinger boring, 3 deglazing. Try to shortcut it, you will be looking at a new powerhead. To install it, you will still need to remove the controls
