chevysam41
- Jan 29, 2016
- 59
Hello All,
I decided to do a full ignition overhaul on my 76 Evinrude 15 (since everything on the motor is still 40 YO OEM...:lol. I think everything else is good to go, but I'm having difficulties getting the points set correctly. I initially installed the points and set the gap to .020 with the breaker shoe at the "set" mark on the cam. Put the flywheel back on and checked the timing with a volt meter. Timing was off on both cylinders, so I adjusted the points to make sure the points were opening between the marks on the armature plate (with the motor in forward gear at WOT). This timing corresponds to "8" on the cam. Timing is now fixed.
The problem is, as the crank rotates and the breaker shoe is aligned with "set" on the cam, the breaker gap increases from .020 around 0.025", which is too large. I've done a bit of research online and it looks like most points on older outboards have two screws securing it to the armature plate (an anchor and an adjustment screw). However, the ones for at least 1976 only have one screw securing it to the armature plate. If I loosen this screw and adjust the breaker to a .020" gap, then it throws off the timing, and vice versa.
My question is once I've adjusted the timing, how do I set the point gap without throwing off the timing? The only other way of adjusting this that I see is a spring tension screw on the side of the breaker...which I thought was supposed to be left alone. Am I wrong?
Also, I see there is a piece of fiber that is supposed to keep the cam lubed and prevent premature breaker shoe wear. Mine is dry as a bone - what is everyone using to re-saturate this? Standard motor oil?
I can post pictures if needed. Thanks in advance!
Sam
Sam
