I have a 1993 90hp with vro removed. It was removed before i bought the boat and is much easier in my opinion to just mix gas and oil. The problem I am having is trash getting in the lower carb between the needle and seat. It has done it three times this year. I have replaced all fuel lines and fuel filters thinking they could have been the source of the trash. Took it out last weekend and the same thing happened again, would not idle but runs great at WOT. I realized it was flooding out. Tore the carbs off yesterday to inspect them and once again found trash in the lower carb. I decided to inspect the fuel pump and found that was the source of the trash(tiny pieces flaking off diaphragm). My question now is: Should I spend the money for a rebuild kit for the fuel pump or replace the pump with a new one that is a non oiler? I have heard that I can use one from an earlier 90hp before vro was introduced.
