rodknee1231
- Jul 28, 2015
- 136
Replaced a piston and rod bearing but that's it. I've ran it on muffs a few times probably a total of 30 min on 32:1 and pitted around on the water once for maybe 20 only about 2 gallons put through so far. I'm using quicksilver sythetic for my pre mix. Factory service manual says to use 50:1 for break in but I'm being safe. Also says for fist 20 min do a fast idle. Then next hour no more than half throttle then the second hour plane out at 3/4 with fill throttle heat cycles. My question is do you guys think I'm ok to hammer down here n there at 50:1 ? I know alot has changed about break in procedures since this manual was released long before I was born haha
