SuperEnzo
- Dec 11, 2014
- 32
Hi everyone,
I have a 1963 Johnson 18hp that came with the matching Johnson 6 Gallon gas tank. My troubles lie with the gas tank fuel connectors.
Recently I did the repair outlined here where you replace the o-rings inside of the fuel pins on the tank: http://www.oddjobmotors.com/tt4_singlelinetanks.htm
Even after that repair the tank is still leaking air and gas. The actual fuel connectors on the lines are brand new and are not leaking. The leak is coming from this pin
Im wondering what i'm doing wrong or if there is supposed to be an o ring or something like on the pin that is leaking because it has a recessed face. This is the only problem keeping me from fishing haha
-Ethan
-Ethan
