Hello,
I have a Sportwin 9.5 that pumped water on its last outing about a month ago, but not now. I replaced the impeller and also the thermostat and it still doesn't pump water out. I pulled the thermostat and ran the engine and no water came out of the thermostat hole. I checked to make sure that the impeller was installed the right way, and from what I can tell it is.
Any help would be appreciated. Thanks!
