Im finally going to add a tell tale. Read a lot of posts, Service Bulletin, etc. Have the tap, fittings and tubing. The SB says to use OMC Gel Seal to attach the fitting to the water jacket.
I dont have the Gel Seal, Posts say that Locktite 515 is an alternate but NAPA doesnt carry but could order for $24. Can I use someting more common like Permatex 2 Non Hardening? Its water without much pressure nor heat.
Any thoughts?
Any thoughts?
