Hello All,
After having a running outboard when winterizing last year, I went to start the outboard for the first time this spring. I charged the battery then attached it to the power cables. I turned the key and all I got was a whirring noise. I opened the cowling and watched the starter as I turned the key again. Same whirring noise and then I saw that the starter gear assembly was not moving up and engaging the flywheel. I first went and bought a brand new battery and tried again, same response. I then bought a new starter, same response. I then attached jumper cables directly to the old starter which I had reattached to the outboard, the gear assembly moved up and engaged the flywheel but didn't have enough power to crank the motor then the jumper cables became hot to the touch.
My question now is, do I replace the Solenoid or do I replace the battery cables that were in rough looking condition?
Thanks for your responses in advance.
