roehrle
- Apr 14, 2015
- 21
Just put my 4th water pump in my 1997 9.9hp 4 stroke Evinrude 10FRELEU. I stuck the motor in a tank and started the motor. The flow from the pee tube was great at 3000 rpm but as I slowed down the speed the flow dropped off until there wasn?t any at idle. I ran it at 3000 rpm for about 10 minutes and measured the temperature near the spark plugs using an IR gun and got a reading of 220 F. The book states it should be 160 +_ 15 degrees. The new impeller I put in the pump was extremely difficult it get in. I had to use a hose clamp around the arms of the impeller to get it in which I never had to do with the other pumps I installed. I read some where that some kits were using impeller that were larger than the old impeller and I was wondering if this was my problem. The impeller is apparently working at high speed so why would an over size impeller not work at slower speeds ?? What would cause the flow to stop at slower motor speeds ??
Any suggest would be welcomed.
Evinrude 10FRELEU
Evinrude 10FRELEU
