I'm getting water in the top cylinder on the starboard side. Compression is good on all cylinders @ 140. I have pulled the head, had it resurfaced and replaced the o-ring gaskets and reassembled but I'm still getting moisture in that cylinder. I now have the head back off and I'm looking for damage to the cylinder but it looks ok to the naked eye. Is there anything that could be causing this other than a cracked block? Any help is greatly appreciated!
