clairmarinelighting
- Apr 3, 2016
- 12
HELP!!! I have a 1985 Johnson 9.9hp outboard with a compression ration of 122psi equal on both cylinder. when I bought the engine 8 months ago it was 130 psi in both cylinders. fuel mixture is dead on 5o to 1 ratio. .non vented tank. the fuel is new as well as the tank. last time I went out I didn't start on the fist pull like it normally did, when I got home I checked the cylinders by pulling the plugs and found a milky substance( oil and water) so I replaced both lower crank seals and associated gaskets orings etc...I replace all water jacket gaskets. and intake side panel gaskets...but still milky. any ideas? the head appeared to be fine no indication of damage or cracks. I have a descent background in 4stroke but I suck in 2 strokes....I have buit several small black race motors and trans..
