redslayer1121
- Mar 28, 2016
- 12
I recently was out on the water and my boat bogged down to almost an idle no matter at what throttle I had it at. When I got it home I noticed I had a crack in my vro pump, so I decided to swap it out with a new star dared fuel pump. I finished the install of the new pump and reinstalled everything, and when I went to start the motor it wouldn't start and then I noticed the lower carb has fuel pouring out of it. I opened the carb drain plugs and the lower carb was filled and the top two had none in them. Any and all help would be appreciated.
