snowforner15
- Mar 3, 2016
- 1
Hi guys, first time outboard owner here. Have owned inboards in the past and done minor maintenance.
Recently purchased 03 115HP 4 stroke on a zodiac. Motor looks to be in excellent shape, no use shown on prop, could eat off powerhead, so decided to buy it without a water trial. Boat has been essentially sitting in a barn since 07 or so, based on all of the registration tags in the file/not on the hull.
Impeller & engine oil was last serviced 2005 (It is Feb. 2016 now) so impeller was my go to. Dropped the lower unit, new impeller in, back together, on the hose- fired right up and purred like a kitten on idle/light rev.
No water from pee hole / tell tale/ water pump indicator, but was coming from prop exhaust and back out the intake vents (I have a hose screw in).
1. Can someone please provide steps to make sure pee hole is not clogged?
2. Please explain where water goes once it it up from water pump.
3. How do I clean intake vents on side of motor?
Per the attached diagram, it looks like I have #5 going straight into #8. I have #7,14 in the mail..
4. Could this make a difference?
http://www.crowleymarine.com/johnson-evinrude/parts/59811.cfm
How do I unclog water pump indicator circuit?
Thanks.
Thanks.
