sutor623
- May 23, 2011
- 4,089
Hey guys. E48esledc. '96 48spl
Got a buddies motor Im trying to help him with. When I first saw the video he sent me, I said "I got this, its a timer base or damaged flywheel." But than I indexed the flywheel, and timing is SPOT ON!! When the motor acts up, each cylinder is only firing when it is supposed to be firing (according to the timing gun and indexes on the flywheel.
I pulled the temp sensor wire and it didnt change anything. Rectifier tests fine, and is not the cause.
The powerpack has already been changed prior to me getting this motor. The issue is when I get the motor to start acting up, I walk around to the back of the boat to put the dva meter to check stator and powerpack output, and the motor RUNS AWAY!!! It will try to run til it blows.
Idles like a happy kitty cat, so cranking DVA will not show the issue.
Stator and timer base are only $50 each. I was going to pull the fly, make sure it isnt damaged, then just change out timer and stator for a whopping total of $100, and have my buddy well on his way.
Here's a vid of it acting up. Only happens at 2000rpms and up.
