pontoonerdon
- Feb 12, 2016
- 3
I am rebuilding the gear case from my 1989 90 HP Evinrude model # TE90TLCEM. I would like to know the dimension of the part # 315767 gauge if any one has it. Also, is it necessary, I am only replacing the thrust bearing and pinion and forward and reverse gears, along with the thrust bearings on them. I am not changing the upper drive shaft bearing housing. I read that using the original thrust shims works fine. Thanks for any info.
