not critical as to sandpaper grade, I use #400 , fold a small piece so both point contacts are cleaned simultaneously when the points are closed on the paper, 4 or 5 passes are usually sufficent, then clean the grit off with some spray carb cleaner while pulling a business card, folded over coffee filter, etc. through.. the idea is to not leave any residue or fibers behind...to really clean them you should remove them from the armature plate and do each contact individually...the described method is the " usually sufficient" method..the point set closest to the carb is for the Top Cylinder...you can just snug the f/w back on to check for spark, don't forget to retorque it when you're finished
