Bearhunter08
- Feb 6, 2016
- 11
Hey guys, I got a 54 Johnson Seahorse 5.5 hp and I am having a bit of trouble with it. Recently I had someone rebuild the carb and I also converted it to run on the mikuni fuel pump. However once it gets running it will idle fine then all the sudden it revs up to wide open throttle and then dies out. If anyone has some info on what could be causing this issue it would be great for your input.
