The service manual cites a max of 20% difference between high and low compression readings. So it sounds like your readings are in spec.
BTW - compression testers are not all that accurate. They should, however, be reliable and read the same number for the same compression PSI. So it is possible for your cylinders to have a lower compression PSI, due to the inaccuracy of the gauge.
