Howdy folks,
I started out thinking I had a prop issue and have since discovered that I am getting very weak spark on the port side cylinders on my OMC 1.6L SEA DRIVE. It's nothing but a 115hp crossflow. Here's the history of it.
I bought it used last year, went through it and ended up cooking a piston and ruining a cylinder due to a bad t-stat. Rebuilt the entire motor, all cylinders bored .064 over, forged pistons installed. All bearings were inspected and found to be good along with all internals and reeds.
I replaced everything else on the motor including coils, powerpacks, and the rectifier. I also replaced the tach afterwords.
I am not only getting around 4000rpms out of it at WOT and it's hitting right at 30mph. This boat should do 40 EASY at about 5100rpm(max of 5500). So I thought it was a prop issue, not so fast!
I went out today and decided to do a quick check on my plugs. Cylinder 1 was almost new looking with very little fouling, 2 and 4 were good and dirty from sitting on muffs idling. The other port side cylinder (3) was dirty but not nearly as much as 2 and 4.
The spark test showed that I was getting a very weak spark on cylinder 1 that would barely hop 1/4" and a little stronger hop on number 3 but not over 1/4".
What causes these powerpacks to get bad. I've read that if kill switch wires get crossed up it can back feed current into the pack. When the motor is running at 4000rpm it's charging battery fine. Is there anything else that could cause this issue of powerpacks failing?
