Frank Biggs
- Dec 31, 2015
- 2
81 model 2 hp Johnson (back up sailboat motor) was running perfectly 3 years ago. Ran the gas out, put a little oil in cylinder and stored in garage. Tried to start it recently, it finally started and ran on fast setting for about 20 seconds, stopped and won't restart. Cleaned carb (not dirty) checked points, okay, good spark, compression 65 lbs., fresh no ethanol gas 50:1. Fast and slow carb adjustments out about 1 turn. What could be wrong?
